Existing externally located steel fame is set in single brickwork and has corroded around the bottom hinges area.
Size - to fit existing double door outward opening solid doors as bought from Bunnings standard floor stock years ago.
Frame was originally supplied by bricklayer when doing the brickwork.
Can supply photos and exact measurements if needed.
