Can you use pedestal footing on pavers?
tarun1arora
I am planning on a low level deck and I am not confident in digging, so considering a modern kind of deck. I have about 140 mm of space and thinking of using 70x35 for framing and 19mm merbau for the top. Which leaves me with approximately 50mm of space.
I have used modular decking foot in past which is about 50mm or I can use the pedestal foot. I used the decking foot on a concrete paver and want to know if I can use the builders edge pedestal footing on top of the concrete paver?? If i use pedestal foot it allows me to use a 90x45 mm frame as the pedestal foot is only 25-40mm.
Re: Pedestal footing on pavers
Hello @tarun1arora
Thanks for sharing your question about using pedestal footing on pavers. The quick answer is yes, you can use the pedestal footing on pavers. This is on the condition that the paver is not cracked, it is flat, level and has a flat surface from which the pedestal can sit on.
Just keep in mind when using the smaller pedestals, you'll need to use more of them to provide adequate support.
