Garden irrigation system
GardenerJohn
New Contributor
Great video on setting up an irrigation system - but what was the point of the water pressure test?
The video showed how to do one, but not what to do with the results? I'm sure it's important for some reason?
Grateful for your advice.
Gardener John
Re: Garden irrigation system
Hi @GardenerJohn,
Welcome to Workshop. We're pleased you could join us. I trust you will find our community members are the source of a lot of helpful information and inspiration for your projects.
A garden irrigation system is certainly a great project coming into the warmer months. I'm sure community members like @Branchy249 or team members at your local Bunnings store will be able to assist you with suitable products for your system once you've worked out your maximum flow rate. Have you already done the test?
For the benefit of other members, I believe John is referring to the Bunnings video below, which is part of a four-part series on installing an irrigation system
Thanks again for joining in the discussion,
Branchy249
Junior Contributor
Hi Gardener John,
The pressure test allows you to identify how many pop up sprinklers you can run off your line at any one time. There are a number of different pop up sprinklers that are available and they all require different water pressures to operate effectively. Some are suited to lower pressures, whilst others require higher pressures to operate. This can also determine how big the coverage of the sprinkler is.
If your pressure is too low, you may need to run multiple lines which can easily be done.
Hi @GardenerJohn,
Just checking in to see if you have managed to do that water pressure test as yet?
GardenerJohn
New Contributor
Thanks Branchy, appreciate your time to reply. Yep, get the principle but I'm looking for the implementation.
I'm guessing there is some sort of ratio - tap flow rate divided by pipe distance and width  (5m x 19mm) to determine the number of trickles I can poke into the delivery pipe.
Any thoughts.
GardnerJohn
DCS
Budding Contributor
Gidday GardnerJohn,
To answer your question as simply as I can, the water pressure test is used to determine the amount of sprinkler heads you can use on the one line. There really isn't a ratio so to speak of, but you do have to know the flow rate of the sprinkler heads. Simply, you just add up the flow rates on the sprinklers so that their flow rate is below the maximum flow rate of the tap.
For example: Your tap will flow at 100 litres per hour. That will allow you to run 10 sprinkler heads that have a flow rate of 10 litres per hour, or 20 sprinkler heads with a flow rate of 5 litres per hour.
Of course with you're dealing with drippers, this information is pretty useless because drippers require very little pressure. Some drippers have a fixed flow rate, whereas some are adjustable.
The rise (the amount of height the water has to travel up hill from the tap) and the run (the amount of distance the water has to travel away from the tap). The rise and run is very important if you use pumps to pump your water around your block but if you use town water it isn't really that important if you live in a city residential area as most places have enough pressure to deal with the average size blocks.
It all depends on what you are trying to water... is it a lawn or a garden bed? Because both applications have a different way of setting up to get the most out of your watering system.
I hope that helps.
Thanks for joining the discussion and sharing your expertise @DCS. I'm sure @GardenerJohn appreciates the advice.
Let me also extend a very warm welcome to the Workshop community. It's great to have you join us. I hope that in addition to enjoying sharing your projects and knowledge that you can get plenty of helpful information and inspiration from our community members.
Please let me know if you ever need a hand getting the most from the site, or have any feedback on how we can make Workshop more useful for you.
GardenerJohn
New Contributor
Hi DCS,
Your information helped enormously. Done the calcs and installed the system today - seems to be working well. Small issue, some leaking where the link to the tap joins the irrigation line connection. Point of greatest pressure I guess. I had used a circular plastic clips to lock the irrigation head to the polypipe. I'll replace it with a metal clip, which I should be able to tighten more securely.
Thanks again DCS.
GardnerJohn
Visitors to this very popular discussion at this time of year might also like to check out these other Workshop posts:
Feel free to post if you need a hand with anything.
