With an upcoming shed install, I will be installing a 600mm high retaining wall using sleepers to retain the upslope earth from the cut required.
On a few test digs, I have noticed solid clay for the bottom 300mm that is holding water for days with no drainage through the adjacent earth. Due to this, will I need to consider multiple layers of ag pipe drainage, one at the base and the other midway up at soil level, or will the base ag pipe do the job?
Cheers
