Hi there,
I'm looking to build a small retaining wall under a section of existing 1800mm Colorbond fence - required after the earth was levelled for a new build. The section of retaining wall will be approx 19 metres in length (8 fence panels) and will rise on a slope from ground level to a max height of approx 550mm. I am thinking of using a composite sleeper solution, but am concerned that using composite fence posts in concrete piers with brackets to attach the fence might not be adequate to support the fence on top.
Wondering if anyone hads done similar and if it was successful?
Many thanks
