How to change an Masport easyrider lawn mower cutting blade.
Hi @Reginald
The easiest way is to type into google "masport easy rider mower manual" you should get a the manual for the mower and exact instructions as they provide.
But Typically changing any mower blade requires locking the mower blade plate from spinning. So you can then apply force to the individual blade locking nutz and every thing is held in place.\ and the nut will undo. Take note as to the direction the blade is sitting as it is possible to put the new ones on back wards.
Hope it is an easy fix for you.
If the nuts extra tight slip a lump of pipe over the spanner to lengthen it and it will give you greater leverage and less grunting from the fixer.
Hi @Reginald,
As @Jewelleryrescue has mentioned, your mower's manual will describe how to change the blade, but it is likely a simple case of removing a nut, attaching the new blades in the correct orientation and then reattaching the nut to the specified level of torque.
Without knowing the exact model of your mower, I can't point you towards the exact manual, but Masport ride-on mowers are listed here. Select your mower then in the top right click the link to the owner's manual to download a PDF of the manual.
If you read the manual and aren't confident doing what they describe, it is likely worth taking your mower to a mower repair service for their assistance.
Let me know how you go and if you require further assistance, please don't hesitate to ask.
Thanks for the advice friend. I am getting pretty old now and the jobs I used to do seem to be getting harder. My main worry was getting the blade to rotate in the correct direction. All will be good now so once again, THANKYOU.
Thanks Mate. It seems the maker of the mower has no on line instructions. Not to worry, with people like yourself around we can still operate. Thankyou.
