Hi All,
Can someone help me to find a 1 inch axle which suit the following wheel? I need it to replace my wheelbarrow's wheel but the existing axle is 1/2 inch and it is not suitable.
Hello @alimilvar
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about getting an axle for your wheelbarrow.
There is a Sherlock Wheelbarrow Standard Axle And Bracket Kit, but its measurement is at 30mm. The only other pipe that is close to the measurements you're after is the Brasshards 25 x 300mm Galvanised Pipe which is close to one inch. But I suspect that it will not be strong enough for heavy duty work.
Please allow me to double check with the store and see if there are any axle's available at the size you're after.
Thanks Eric. Appreciate your help.
Thank you for your patience. I've been in contact with our suppliers and Sherlock Wheelbarrows has an axle that is very close to one inch it is technically 24mm. This spare part will need to be ordered at the special orders desk. I suggest speaking to a team member at the special orders desk and asking them to quote you how much a Sherlock Wheelbarrow axel will cost. The part number is "BPAXLEKIT" the description for the part is Sherlock wheelbarrow axel kit.
Awesome! Thank you Eric.
