I have a irrigation timer with a 12mm outlet. Unfortunately, there is a leak between the WX2 timer's 12mm outlet and the connector I am using to attach the polypipe. I have attempted to use PTFE tape on the connector and also without tape, both times the leak continues. Rubber seal inside the connector's looks intact. Water pressure from the pipe is not exceeding the limits of the timer, which I have calculated to be around 341 KPa. The Timer is rated to take upto 800Kpa. The poly pipe has been cleanly cut and I have made sure that it has been inserted all the way into the connector. I have also used the ratchet clamps on the barb joints.
