what would be the best weed killer for these on the photos? Thanks
Hi again @adamlin,
You might like to provide members a little more information so they can assist you with combating the weeds. Do you know what type of lawn you have? And where are you based?
I would recommend you have a look at the popular discussion How to improve your lawn this Spring as it is full of helpful tips on getting your lawn ready for the warmer months ahead. This discussion also has fantastic advice from @MitchellMc that you should be able to apply to your situation - Lawn weed.
Many thanks,
Hi Jason, @Jason actually not too sure about what lawn it is frankly speaking but could be Buffalo? Are you able to tell on these photos? Thanks
Hi @adamlin,
@Adam_W and @Noelle may be able to bring insights here.
Stevie
Hello @adamlin
It's great that you've received excellent advice from @Jason. The discussion he has referred to - Lawn Weed refers to procedures you need to take with your current condition. In it, you will find fantastic advice from @MitchellMc on how to combat weed infestation. I also suggest using traditional methods of weeding using Fiskars 4 Prongs Xact Weed Puller for those deep-rooted weeds.
Turf that has been infested often happens in small batches. Often we mow over them and ignore the weed. Weeds like any other plant react to this by sending signals of immediate growth and replication. This is why it has to be taken out early as soon as you see any buds or growth occurring in your garden.
My only other suggestion is to identify the zones that your weeds are in and till the area. This will loosen the soil and allow you to remove the wide-spreading roots of the weed. Areas that have been taken over will need to be patched if the weed infestation is too great. You can patch these areas with Sir Walter's 0.5m² DNA Certified Soft Leaf Buffalo Turf Slab. Please keep us updated, we look forward to seeing your lawn free of weeds.
Hi all,
Any suggestion to get rid of the expanding weeds as on the photos?
please help
Thank you for sharing your question about lawn weeds. Looking at your picture it seems you have an infestation of bindi, before waging any sort of chemical warfare on your turf, I suggest manually removing as many as you can using Fiskars 4 Prongs Xact Weed Puller. This will make removing the weeds much easier as this tool is purposely designed to extract weeds from your garden.
Once you've removed as many weeds as you can, I suggest using Yates 2.4L BuffaloPro Weed 'n' Feed Hose On Weed Killer. It is a lawn weed killer that selectively kills the most common broadleaf weeds in lawns. It has added fertiliser for rapid greening of the lawn and is safe for buffalo and other common lawn types. A far safer option if you’re unsure what lawn type you have. One bottle will treat an area of 120m2 meters.
Let me tag our experienced members @Noelle and @Adam_W for their recommendations.
Hi @adamlin
Looking at these most recent images, you have lots of dandelions and clover in the lawn but I can't see anything I would identify as bindii. However, the treatment @EricL has suggested will combat these broadleaf weeds quite well.
You may need to follow up with just a lawn weeder product such as Lawn Builder Bindii in a few weeks, as clover can be rather persistent. Combination products (lawn fertiliser and weeder in one) should not be applied too frequently because there is a chance too much lawn food could cause burning of the lawn.
My apologies to you and @Noelle for misidentifying the weed. I always get my lawn weeds mixed up.
Hi Noelle,
Thanks for the weed info!
I had been told by the local bunnings staff that my lawn was not buffalo (I showed her the sample) that is why i 've sprayed the Yates Weed n Feed c couple months ago but did not work looks like. Should I keep using that still or should use lawn builder bindii instead and how frequent it should be?
thanks
No Problems Eric. Thanks
Let me tag @Noelle to make her aware of your questions. The Weed n Feed usually takes about three weeks to take effect. However, if you don't get any results, I suggest holding off on respraying the Weed n Feed until we got some recommendations from Noelle. We don't want to oversaturate the area with too many chemicals as it is probably not good for your turf.
Hi again @adamlin
Lawn weeds are notoriously persistent - it often takes two or three applications of lawn weeder over a period of months to gain control.
Feeding a lawn at this time of the year is not really recommended so I would stick with the Lawn Builder Bindii. Allow 4 - 6 weeks between applications to give the product time to be absorbed and to work at a time when soil and air temperatures are low and the action of products like these is similarly slow.
I'd hold off on using any type of fertiliser (granular or liquid) until late August - September when temps are starting to warm again and lawn growth is speeding up.
Morning @Noelle
Thanks indeed for the helpful tips.
@EricL Thanks Eric
Hi, I was just wondering if anyone could tell me what kind of weed this is and recommend a weed killer I could use without killing the buffalo grass please? It's only on about the left part of the garden, and there's a LOT of it. It starts off green, and then after a few days it turns white and when I pull it out of the ground, it seems to have a sticky sap on it.
Hello @Merc75
My apologies for the late reply. It might be a type of cudweed; would it be possible for you to please take a photo of the mature weed (specifically your third photo) along with the leaf structure at the bottom of the weed? Once we can identify its structure, we'll be able to confirm what kind of weed it is.
However, I also see that your lawn is infested with clover, and I therefore suggest using Yates 2.4L BuffaloPro Weed 'N' Feed Hose On Weed Killer.
Let me call on our experienced members @Noelle, @mich1972 and @robchin for their opinion.
@EricL I am not sure about this one sorry.
Hi @Merc75
It does look a bit like cudweed, as Eric has said. If that's the case, then the lawn treatment he has recommended will also control it as it is a broadleaf weed, and the product mentioned is a selective lawn weedkiller for the control of broadleaf weeds.Make sure you read the directions for use on the label before applying.
As both clover and cudweed can be difficult to eradicate completely with just one application, you may need to repeat the spraying about 6 weeks after the first.
