Hi @nagumuthu,
Let's start with your concern about access: having 0.9 metres of space on each side of the house does provide some access to the backyard, but it’s quite limited. While it’s technically possible to complete backyard work like filling, levelling, and installing artificial turf after the house is built, the narrow access can make it significantly more challenging. Equipment such as mini-diggers or narrow access machinery can just fit through that width, but transporting materials in and out will be more labour-intensive and costly due to the constrained space. You may find yourself relying on wheelbarrows and manual labour where small machinery would otherwise be used.
Construction activities pose a real risk to any finished landscaping. Materials, tradespeople and things like scaffolding can damage newly laid turf, shift filled ground, or compact soil unevenly. There’s also the risk of drainage being altered during the remaining build process, which could create water pooling or erosion in newly levelled areas.
While it would probably be best to leave the actual installation of things until after the work on your house is complete, it might be worthwhile having materials delivered and moved to the backyard while access is still good and machinery can be used. This would need to be coordinated with your builder, but it would make things easier down the line.
Most councils do allow homeowners to complete general landscaping such as laying turf, building garden beds, or planting. Exceptions arise if you're planning significant earthworks, altering drainage, or building retaining walls over 600mm high. It’s always smart to check your local council regulations or review your building approval documents to ensure you're not overlooking any site-specific requirements. Also, don't forget to use a service like Dial Before You Dig to avoid any issues with underground services, especially if you're planning any excavation.
As for budgeting, it is extremely difficult to say without knowing all the variables, but I would probably be budgeting somewhere in the region of eight to ten thousand.
In summary, it’s feasible to do the landscaping after the build, but it will likely be more expensive and time-consuming due to limited access. If you can take advantage of the current open access to at least move materials in, that would be a smart move. Just hold off on installing anything permanent until construction is complete and ensure you consult with your builder to ensure it is not going to get in their way.
Allow me to tag @Nailbag, @Dave-1 and @JoeAzza for their thoughts.
