Hi team
I was hoping someone can help me with a project I've been putting off since I moved into my first home! The goal is to remove the old grass, level the ground, install new grass (Sir Walter Buffalo for its shade tolerance and low maintenance) and fix a sloping fence (Photo 1).
Our backyard is a rectangle 5m x 10m (Photos 1 & 2).
I have a small dog and would prefer methods that take less time and that aren't poisonous to him so he can enjoy being outside! But I also appreciate that this might not be practical for this project. I’m also fine with some manual labour!
Removing Old Grass
Our grass has always been really patchy and the ground very uneven (Photos 1-5). There's also an area which doesn't get any direct sunlight which makes it muddy after rain (Photos 4, 6 & 8).
I've looked at different ways to make the ground even from using machines to remove the grass and then hiring out big tools to compact the ground to doing it by hand - and it's overwhelming to be honest!
I was thinking of:
- Testing the soil’s PH level
- Checking with Before You Dig
- Removing any weeds with Fiskars 4 Prongs Xact Weed Puller - Can’t use chemicals poisonous to pets
- Mowing the lawn on the lowest setting - though the uneven ground usually means the grass won't be evenly cut!
- Maybe using a Sacrifier
- Watering the grass to make digging it up easier (unless it was recently raining)
- Using a flat shovel to turn the grass into strips that can be rolled up
- Cutting the strips in small sections by pushing the shovel beneath the grass and lifting
Does this sound right? I've got some questions:
- Is using a Scarifier necessary? I've read about other people using one for similar work and that it could help with the area that's usually damp
- Once the grass is removed and there's just soil, what should I do to make sure there's no grass or weeds remaining before installing the new grass?
- Should I wait before preparing to install the new grass? If so, why and how long?
Levelling Ground + Fixing Tilting Fence
Our backyard has divots, is slightly slopped and has areas that sink near the back neighbour's fence (Photo 1, area covered by tiles because the ground sinks underneath the sleeper, photo 8). The ground is also not level with the wooden sleepers used to separate the side of the house (Photos 3 & 5, small hole on the left courtesy of my cheeky pup) and those under the fence with our back neighbour.
Our biggest issue with this unevenness is that the fence with our back neighbour has started to tilt towards us in one area and we've needed to prop it up (Photo 1, thanks chairs!)! I think it's because their backyard is lower than ours by a bit, which is why there are wooden sleepers (which have gaps) beneath the fence.
An annoying part of our backyard is that one area just always stays muddy, even days after a rain. I think it's because this area gets no direct sunlight. I'm hoping that levelling the ground and adding topsoil might help with this problem, but I think a garden drain / French drain might be needed in the future (Photos 4, 6, 7 & 8).
I was thinking of:
- Using string and stakes to indicate the height of the soil. I was hoping for this to be the bottom of the back fence above the wooden sleepers, but that may be too high given the height of the side fence (Photos 1, 2 & 9)
- Adding topsoil up to string height - though the gap above and beneath some sleepers on the back fence might cause some dirt to fall into the neighbour’s yard (which is lower than ours). My hope is that the extra soil will stop the fence from tilting
- Using a spreader to even the ground
- Sprinkling wetting agent then fertiliser then watering the ground
A couple of questions:
- Do you think the height (bottom part of back fence, above sleepers) is too high?
- Is there something I can add to the fence sleepers to make sure the fresh topsoil doesn't spill into the neighbour's yard? I think the builders added some cement to the poles when installing the fence so I don’t think I can adjust the height of them. If possible, something not wooden
- Is there something else I can do to stop the fence from tilting?
- Would I need to rent a compacting machine or other tool to manually compact the ground or is using a spreader enough?
Laying the Grass
Once everything else is set, I would lay Sir Walter Buffalo grass following the Bunnings 'How to lay turf' DIY guide.
Thanks for reading!
Photo 1
1
Photo 2
2
Photo 3
3
Photo 4
4
Photo 5
5
Photo 6
6
Photo 7
7
Photo 8
8
Photo 9
9
