Hello Members
Can you please propose ways to avoid weed intruding weed mat and growing further.
Below photo is taken in around 2 months after laying the weed mat.
Thanks.
To add on, Affixed Single layer of weed mat and wondering Should 3 layers of weed mat be placed.
Hello @nagumuthu
Thanks for sharing your question about the weed mat. Weeds are tenacious plants and find ways to overcome the barriers we place in their way. In this particular situation, I suggest moving the rocks and weed matting to mechanically remove as much of the weeds as possible. When putting the new weed mat on top, make sure that the edge is pinned very well to the ground and that there are no holes or cuts in the weed mat that will allow the soil to be exposed to light.
Using two weed mats should be more than enough to prevent weeds from growing for some time. But please keep in mind that eventually the weed mat will wear out and the weeds will find an opening to grow into.
Hi @nagumuthu
My experiance is dirt and seeds fall onto the weed mat and the weeds germinate on top of the weed mat sending roots down in through the mat.by passing you mats protection or growing around the edges from underneath.
You really dont want to spray poision near your roses.
So I use small a 10mm wide artist brush and have a jar of weed killer at high strength and I simply paint a couple of the weeds leaves. and they die in a week or so. Theres and old gardners saying (One year of seed is 7 years of weeding) Dont let them go to seed. Pulling them out can leave roots behind and your wasting your time plus its a lot of bending which is not easy for every one.
Tip : add a 1 to 4 drops of dishwashing detergent into your jar. or your weed spray bottle it breaks the water/ poision mix surface tension and wets the plant and not form drops that run off.
Make sure you dont poision when rain is due as this can wash off to your roses.
If you all ready have big weeds this machine works a treat to thin the jungle.
Hi nagumutha,
Weed mats are not designed to stop weeds altogether, but create a barrier to reduce the weed roots becoming fully established. It makes weeds, typically easier to remove. Extra layers could be tried, but won't stop weeds altogether. Unfortunately where there's dirt, there's going to be weeds. There used to be a Zero brand weed wand, which I don't know if you can still buy. It worked as an alternative to a spray. The poison soaked a wick and this was touched onto the weed so there was no overspray to affect nearby plants. Very effective especially for a small area or rocks like you have. Hope this helps.
@kacharash4
Yes the weed wand we own it too thanks for sharing that information we where hoping it would be the ideal tool.
Basically FYI you had to mix the plant poision and pour it into the container above the wick and that was great it worked. But after each use your supposed to wash it out other wise the wick can leak and or become glugged up with old poision. So it wasnt as practicable as first thought.
The paint brush in the jar isnt perfect either just a little more quicker to use each weeding session I had to cut brush length to fit in jar and use gloves a must. But it works as a spot weeder between wanted plants much safer than spraying.
If you want a complete weed barrier getting old newspapers and laying on the ground over lapping them is still very effective and will last a year or two as they break down. This seams not to hurt the worms either.
Black builders plastic will sterailze the ground almost as the heat build up helps kill weed seeds too. But on a garden it stops water getting to your wanted plants roots so much care is needed here.
The best solution is a little weeding often off the weed mat before they seed and get too big and the weed mat pulls up with weed.
Hello @kacharash4
Thank you very much for sharing your ideas on weed matting. Let me tag @nagumuthu to make them aware of your suggestion. I'm always afraid for plants that get too close to poison. I suppose you would only place the weed wand in large weed infestations and away from your trees.
Again, thanks for sharing your knowledge.
Hi @EricL
Actually on a dry day you can reach in with a wand or brush in a very populated plant garden and paint the weed (only one leaf is enough) and it dies like its being surgically removed with no other plants effected as there is zero risk of over spraying.
Technique could be used in surgery 1 drop of rattlesnake poision into a tumor would disolve it? Ok I better not setup my DIY hospital lol. But rattlesnake venom will disolve tissue just need to get quantity right.
