Hi, I am building a narrow low level deck around a pool, and I am trying to work out the spans needed. I have looked through all the bunnings threads, including https://www.workshop.bunnings.com.au/t5/How-To/How-to-build-a-low-level-deck/ba-p/45715 but there isn't anywhere that provides the recommended span tables - and in relation to the structural type of wood bunnings sells (e.g. MPG).
Being of technical mind I find the span tables easy to follow, but ones that I find on the internet can vary greatly for even similar wood sizes and also vary depending on the structural classification of the wood. The wood I would like to use is the Bunnings 90X45 and 140X45 MPG H3.
The floor load width in many areas is 0.5m, as the deck is very narrow. The deck has lots of thing strips to go around a pool. Often the span tables don't have such small floor load widths. Using the lowest FLW available the number of bearer supports is getting rediculous, and then needing a mind boggling amount of concrete if one follows the specs for foundations. This is resulting in more concrete per area than the slab for the house. It is getting silly!
In summary, please provide the span tables bunnings recommends.
Matthew
