I hope someone can enlighten me. I want to drill drainage holes in small and larger porcelain bowls to put succulents in. I did manage to drill holes in 3 bowls (which took a very long time on full power). The bit + the drill became very hot and now the bit is stained blue. I used a 6mm tungsten carbide centering tip that goes through cement and tiles (indicated on packet). The man in Bunnings Tools recommended it. I tried with other bits - larger ones. Then I tried with other bowls but it didn't make holes. I thought I had burnt the bit out - is that possible?So, I bought the same bit again using less power but there is only a tiny round break not a hole in the bowls. I compared the old to the new bit and they look identical. PS: didn't use the Hammer function. Is it normal to take so long to make small holes - talking 10 minutes + for each hole on full (very noisy!). Got any advice? Thanks, Deborah
