hi I have some lengths of 50mm diam agi pipe I’d like to use in my paddocks for drainage into a sump pit. Does the agi sock 50mm stretch enough to go onto this or do I need to get the next size up please?
cheers and thank you
janet
Hello @Fixit77
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thanks for sharing your question about agi pipe.
It all depends on the length of your agi pipe, is it long enough to cover the area and will it reach the sump pit? I propose laying it out so that you can actually see if its long enough for your needs. Keep in mind that 50mm is not that big and if you have a lot of water overflowing then getting a larger pipe such as the Vinidex 100mm x 20m Socked Slotted Draincoil would be more practical.
Hi again,
I haven’t laid it out yet but great idea. I’m more asking if the 50mm diam sock would fit the 50mm diameter pipe - not length just is the sock meant to be snug or
loose ?
janet
Hi @Fixit77
It should fit neatly on the condition that the sock is compatible with the agi pipe. The only way to find out is to test the fitting.
