What garden auger is suitable for DeWalt drill?
ironbark
Building a Reputation
Hi, I’m looking for a suitable DeWalt battery drill that I can use with a garden auger. It obviously needs some sort of slip clutch that stops if it should hit something solid, for safety reasons.
any suggestions or recommendations would be greatly appreciated.
many thanks😊
Re: garden auger suitable deWalt drill
Hi @ironbark,
If you are already on the Dewalt system, then you would want to look at a higher-end, brushless drill such as this DeWALT 18V XR Premium 3 Speed Hammer Drill Driver.
It will have much higher torque than entry-level models, and it has an Anti-Rotation System for enhanced control in bind-up situations. If the drill senses that the bit has bound and the tool is starting to rotate unexpectedly, it immediately cuts power to the motor. This stops the rotation, protecting the user from a kickback.
Ultimately, drilling into the ground will still be heavy work, and there is always going to be potential for kickback. For this application, using the side handle is a must. This will give you even more control over the tool in the event of kickback.
Have a look at the tools listing on Dewalt's website here -18V XR Premium Brushless Hammer Drill Driver.
I would also consider grabbing a high-amp battery such as this DeWALT 18V 8.0Ah Power Tool Battery if you didn't already have one. You will get much more power and runtime from a larger battery, and from experience, jobs with high torque requirements go a lot easier with a bigger battery.
AlanM52
Amassing an Audience
Re: What garden auger is suitable for DeWalt drill?
Hi @ironbark,
Can you post a picture of the the garden auger you intend to use.
Cheers
