Can Kaboodle kitchen doors be cut to non standard size?
gaylem
Can the kaboodle kitchen doors be cut to non standard size. I only want to replace the doors
Re: Can the kaboodle kitchen doors be cit to non standard size. k onky want to replace the doors
Hello @gaylem
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about Kaboodle doors.
Technically the Kaboodle doors can't be ordered to custom sizes, but you can order custom sized panels which you can use as doors for your kitchen. Please note that it will be necessary for you to drill your own hinge mounting holes in the door to match your old door set. I suggest using the Hafele Hinge Mounting Kit to cut the holes for your panels. I recommend double checking the measurements of your doors and getting a quote from the in-store kitchen specialist. Please note that kickboards and side panels will need to be ordered separately and is subject to availability.
