Hi Bunnings community members and experts,
To prepare for our incoming first 60cm dishwasher, I’m preparing the location where the unit will be installed.
May I seek for an advice from our experts regarding the inlet valve and drain hose? Some plumbing site says that it is required for the inlet valve to have a mini stop tap and a pressure limiting valve. Looking at my existing connection, I have the below valve under my kitchen sink which is connected to the cold-water pipe (looks like an aux valve). Is this enough or do I really need to replace or install another attachment for the pressure limiting valve?
Second is for the drain hose, most manufacturer instruction is to create some sort of a high loop by attaching the hose to the underside of the cabinet, then to the drain.
This is what I am thinking to do, yellow is my illustration of how I will route the drain hose, from the access hole, then goes up (behind sink) then goes around the sink, ending in the drain. The hose will have a 850mm total height from ground level. Problem with this is it will be difficult to impossible to secure the host behind the sink because of the tight space (not unless I can find a long screwdriver to reach it)
Blue line is the second probable route of the hose from the hole then secured to the second panel of the cupboard then to the drain. Hose will have a total height of 490mm.
What is your advise / opinion regarding these two possible route? Is yellow workable? (may need extension hose) will blue cause draining problem or is it even compliant?
