Does SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel use food grade glue?
dannyboyau
Is the glue used in the SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel safe for contact with food,. Can I use the SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel for making kitchen chopping board. Thank you
Re: Does SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel use food grade glue
Hello @dannyboyau
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about Acacia timber panel.
Please allow me to send a query to our supplier regarding the adhesive of the Acacia panel. As soon as we have more information, we'll get back to you.
Thank you for your patience.
Thank you
Re: Does SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel use food grade glue?
Hello @dannyboyau
Just letting you know that I am still following up the supplier in regards to the SpecRite 2400 x 900 x 33mm Brown Acacia Multi-Use Timber Panel. In the meantime, I suggest having a look at this featured project - Tasmanian Oak chopping board by @AnitaP
Hello @dannyboyau
Thank you for your patience. We've checked with our supplier and the panel is fine to use as a chopping board as long as the timber has been sanded down with the protective oil coating removed and a food safe stain/oil such as Feast Watson 250ml Kitchen Timber Oil has been applied.
Thank you, I will go pickup a panel
