How do I change the hot and cold flexi hose leading to my kitchen mixer tap as it is rusting? The flexi hose in Bunnings have two female ends which is different to what leads into the mixer tap. Am I able to buy these special hoses or do I need to replace the whole mixer tap?
Hello @JoJo133
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thanks for sharing your question about changing your flexi hose under your kitchen tap.
There are three common types of flexi hose:
I suggest turning your mains water off and bringing one of the hoses to the store to make sure you are getting the one with the right length and the right ends. I recommend using Kinetic 12mm x 10m White Standard Thread Seal on any exposed male thread fittings, except for the flexi hose with the small end that goes into the tapware (top one pictured below).
Please note that it might be necessary to engage a registered plumber to complete this work. If in doubt please consult your local building authority before starting.
I've placed some images below to give you an idea of what they look like.
If you have any other questions we can help with, please let me know.
Thank you for adding the pictures, that is very helpful. It is the stainless steel mixer hose that I need (top picture).
Hi @JoJo133
Please remember to bring your old hose to the store so that you can compare it to the length and size of the new one.
