I'm hoping to instal something similar to this picture above my kitchen bench. I’d like to buy the brackets in white and add floating white shelves. Does anyone know where I’d buy the brackets from? Thx for any advice.
Hello @Kaz21
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your question about a kitchen shelf.
I'm so sorry but I'm not sure where to get these ceiling brackets. However, I have seen them replicate something similar with the following parts.
The parts mentioned are for one shelf bracket set only. You will need to repeat this assembly three times. I recommend washing the pipes in soap and water to remove the oil and grease coating. I suggest using the White Knight Rust Guard 400g Grey SLS Etch Primer Spray Paint to prime the steel and then use 2X Ultra Cover Matt Black spray paint to cover the entire set.
You can use a 1200 x 300 x 18mm Hevea Finger Jointed Panel as the main shelf itself. However, if you feel you want a bigger shelf please make sure to change the center support from 300mm to 400mm. It sounds like a fantastic plan, any updates on your project while installing it would be much appreciated.
