I have to fill in a 100mm gap to fit a new wall oven in. The old oven is 700mm wide. The new oven 600mm wide
I have two 50mm x50mm x 600 mm long pieces of dressed hardwood. Can I glue them to the existing cabinet wall
or is it better to screw them to the existing cabinet.
I do not have any photos or video as the old oven is still there.
Hello @Walloven
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your wall oven cabinet.
I suggest aside from using glue, I also suggest installing a Carinya Flat Bracket or similar at the back of the panel so that it will not move even if accidentally leaned on or pushed.
