I have a black and silver flex Bench top that has a deep crack running through it what can I use to fix it
Hi @tmth
Sorry about your bench top.
The best material to fix the situation is epoxy. In your case black epoxy maybe the best.
So I offer the following as a potential solution basically you put the epoxy into the crack flush .
I like to get wide sticky clear smooth tape maybe like the packaging tape and I would put a tape on top and the aim is to get a smooth glass like finish.
This above process is subjective as to best results so just filling the crack maybe the best way or allow a slight bit of glue sitting proud just a tiny bit as a find grade wet and dry sand paper 1200gt can smooth if flush again.
I/N: 1560097
$19.65
Hope this helps.
Hi @tmth,
Welcome to the Bunnings Workshop community.
Great to see you get a prompt response from one of our most experienced members. I trust it is helpful.
Could I also please trouble you to share some photos of your benchtop so our resident Bunnings D.I.Y. experts can see what you are working with and share their thoughts on the repair?
Thanks,
