I’ve over sanded my wooden table and now the patches really stand out. Is there a way to fix this?
Hello @ashnagisa
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about over sanding your table.
I see what’s happened. You’ve sanded back through the topcoat unevenly, so now lighter raw timber patches are showing against the remaining finish.
If you are aiming for an even painted look, the best approach is to lightly sand around the edges of the patches, so they blend more smoothly into the surrounding surface. Once the transitions are softened, apply a thin coat of primer or undercoat to the exposed timber so the paint absorbs evenly, and then repaint the whole tabletop with one or two coats of your chosen finish.
If you prefer a stained or natural timber appearance, you will need to sand the entire surface back evenly to raw wood, as partial sanding will always show through as patches under a stain. Once the tabletop is completely bare, you can apply a stain or clear sealer for a uniform look.
Another option is to embrace the rustic effect by treating the current patches as part of a distressed style. You can lightly scuff other areas to balance the appearance and then seal it with a clear matte polyurethane or a furniture wax so that it looks intentionally shabby-chic rather than accidental.
The fastest repair is to spot-prime and repaint, while the more time-consuming option is to sand right back and refinish, so the choice depends on whether you want a crisp painted look, a natural timber finish, or a rustic distressed style.
Let me call on our experienced members @daniknight4 and @lifestylebymari for their recommendations.
