Hello, I bought a practa solution (marble) benchtop and after 3 attempts of trying to cut the edging ran out. First one chipped, second one was slightly too short🤦🏻
Is it possible to buy practa solution edge strip to have another go?
Hello @rennochap23
I suggest going to your local store and speaking to the team at the special orders desk. Just let them know that you wish to order a cover strip for the Practa solution marble benchtop. You can also speak to the in-store kitchen specialist as they will also be familiar with the cover strip for the Practa benchtop.
My best suggestion is to use a Stanley Knife to cut the cover strip. It will require several passes until you get through the thickness of the cover strip.
Thanks so much. I ended up joining two pieces together on a single edge. Doesn't look perfect but good enough given the pattern is marble and has lines that help blend it in.
Hi @rennochap23
I'm glad to hear that you've managed to patch the edge of your benchtop. Please make sure to post a photo update of your project so that our members will be able to see what you've been working on.
Job done.
4 xIKEA nordli modular drawers joined together
Fixed to the wall using 4 x 65mm dynabolts
Sitting on a 30x30 square pipe as a ledger that is fixed to the wall above skirting with 8 x 100mm dynabolts
With a 2.4m H2 35x70mm piece of wood with legs every 800mm to support the front load.
All under $1100 + my time.
Very happy with the results.
Also an end piece from Bunnings screwed to the end to give that built in feeling.
The empire contour gauge was a big help here.
Love your work @rennochap23!
Many thanks for sharing your results.
