How to replace undermount rangehood?
Sugar
Making a Splash
Hi all
There used to be mirror screen at the bottom of the Range hood to block the oil etc, which broke down.
This is old style Rangehood, from what I can see, I guess.
The size of the Rangehood is 600mmx190mm.
Is there any chances I can get a new Rangehood to replace this, until I do the renovation next year :laugh:  ?
Sugar
Making a Splash
Re: Replacing old Undermount Rangehood with New Range hood
The current brand is "Blanco".
Hi @Sugar,
The brand is a good start, but can you identify a model number?
There is a seller on Bunnings Marketplace who has spare filters like this Blanco Rangehood Rangehood Filter and Spring GF07AA. Considering the plans for renovations in the near future, if we can identify the model of your rangehood, it might be easiest to just replace the filter.
If you'd prefer to replace the whole rangehood, we will need to know the depth as well as the dimensions you've provided, as the doors of the cabinet limit the size of the space. Assuming there is enough depth, something like this Bellini 60cm Slide Out Rangehood White Finish with S/S Fascia seems like it would work.
Let me know what you think.
Thanks @JacobZ
Following are more details about the Rangehood.
 I have included in the model number there.
the overall size is 600x290x300 (WxDxH).
if this whole new thing comes around 150$, I rather change the whole thing now.
Hi @Sugar,
Unfortunately, I couldn't locate a replacement filter for your model of rangehood.
If you're happy to replace it, then you could certainly do so. I've just noticed that your rangehood is a recirculating style rangehood, so you would need to use something like this Bellini 60cm Recirculating Slide Out Rangehood White Finish With Stainless Steel Fascia instead.
The instructions for installation can be found here - Bellini BR603FRW2-F Instructions.
Hi @JacobZ, lookslike this product is not available, at least the website does not show this. Any other similar product you think.
P.S. Looks like this one
Hi @Sugar,
The rangehood you've shown there would be similar. Most 60cm slideout rangehoods should suit your space.
