Steps
Step 1
I don't know why its took me so much of my septuagenarian life to work this out but I am not alone in this regard as EVERY Youtube on the subject off how to defrost a fridge freezer talks about using towels or rags to mop up all of the water that comes from defrosting the freezer in a fridge freezer. I have done it twice with this method over the past few months and it works a treat! Yes, most of us probably have frost free fridges these days but that is not always the case. For example, my little "bar" fridge is not a frost free fridge and every now and then I cannot open the freezer part because it has frozen over with ice. This is how to defrost such a freezer without making a mess and having to be vigilant in watching the defrosting process regularly and mopping up as it proceeds.
Step 2
The secret is simply in using capillary action on some sort of a open weave wicking cloth to get rid of the water from the melting process into an easy to carry container.
Many fridges will have a tray under the freezer to capture any dripping water.
All I have done is to shove one end of a piece of a "Chux" type wipe into that tray and suspend the other end of the wipe into a plastic tub with handles to make removal of the tub full of water easy.
As the ice melts into the tray, the water will wick itself down the wipe and drip, drip, drip into the plastic tub. Too easy!
Step 3
If however, your fridge freezer does not have a tray under the freezer to collect the water, all you would have to do is get a tray of a suitable size that fits on the top shelf under the freezer to collect the drops of water and wick it away from that tray using the method described above.
Step 4
This is cheap project. all you need is a big enough tub to collect the water. I used a $3.50, 16 litre, Ezy Storage tub from Bunnings and a piece of wipe, which in my case was a piece of the more industrtrial width and strength wipes that Bunnings sell but I reckon any open weave domestic Chux type "wipe" will do the trick.
I could show a video of the drops of water going into the tub but it appears that videos cannot be uploaded to these pages.
