Bedroom Makeover for my daughter using Easy Craft VJ panelling and picture railing.
https://www.bunnings.com.au/dulux-4l-vivid-white-low-sheen-wash-wear-interior-paint_p1370158
Plunge Saw: https://www.bunnings.com.au/ozito-165mm-1200w-plunge-track-saw-kit_p6290615
Gorila wood glue: https://www.bunnings.com.au/gorilla-236ml-wood-glue_p1662680
Nail Gun: https://www.bunnings.com.au/paslode-16ga-trimmaster-cordless-angled-bradder-kit_p0369825
Cutting in brush:
https://www.bunnings.com.au/monarch-38mm-cutting-in-and-framing-synthetic-paint-brush_p0319007
Roller Kit: https://www.bunnings.com.au/uni-pro-230mm-10mm-nap-you-can-do-it-paint-roller-cover_p1660040
Painters Tape: https://www.bunnings.com.au/frog-tape-24mm-x-55m-delicate-surface-masking-tape_p0088299
Measure and Cut panelling to size using your track saw.
Place panelling on wall, connect the panels using the Gorila glue at the joins. The panelling will click into each other.
Once all panelling is on the wall secure with nails.
Punch nails using a nail punch and fill with putty. Once dried sand back in preparation to paint.
tape up wall for Paining
Use a cutting in brush to cut in and paint the grooves.
While the paint is still wet complete the area with a roller.
Place skirting and picture railing on, punch and putty the nails and paint your desired colour.
BEFORE PHOTO:
Thank you! So true, I find the panelling can transform the entire space. Very happy with the outcome ![]()
Thank you! It was definitely easy to do and I think any beginner could give it a shot ![]()
Thank you! they are from Adairs ![]()
