I bought a spec rite timber panel 2200x600x26 and I need to legs to install panels use as a table I was suggested to nut bracket but it’s not a proper size and unable to install.
if someone could assist would be be appreciated
thank you.
Hi @4026,
A warm welcome to the Bunnings Workshop community and apologies for the delayed response.
I'd suggest picking up some Adoored 3/8" Vertical Leg Plates, attaching them to the acacia panel with the provided screws and then screwing the leg into the plates.
This will create the tension required to give you a good sturdy connection and a solid table.
Hi Jacob,
thank you for your reply. It’s difficult to cut the nuts for me. Is there any other legs I can use?
Unfortunately, all of the timber look legs appear to use this same bolt and bracket system. If the issue you are having is because the bolt is too long and is hitting the panel above, a cheap solution is to cut the bolt with a Craftright 300mm Tubular Hacksaw. This would not be particularly difficult, requiring you to measure, mark and then cut the bolt off to a suitable length.
If you didn't want to do this, there are plenty of options for legs that will not require any adjustments such as these La Paz Steel Tube Table Furniture Legs, 700 x 50mm Black Steel Table Legs, or 60 x 710mm White Round Adjustable Table Legs.
These can all be installed with 20mm Button Head Timber Stitching Screws.
Let me know what you think and if you have any further questions.
I have the same issue and am puzzled as to why Bunnings can't cut the hanger bolt for the (layperson) customer. However, I've ordered small timber rings from elsewhere to pack the space. Hopefully that works.
Hi @RaeRae_K,
As these products are designed to be used in a variety of situations, unfortunately, they don't always go together in a perfect way. I understand your frustration and am happy to offer my assistance if required.
Adding some packers so the bolt does not bottom out certainly seems like a good solution to this issue.
You could also drill out a hole behind the plate using a spade bit to create space for the bolt to go through at full depth.
Let us know how you go and if you require any further assistance, please don't hesitate to ask.
