I have some wood table which all surfaces are sticky. How can I clean the surface?
Hi @Kourosh,
What have you tried to clean the surface with so far? If standard multi-purpose cleaning products haven't worked, then perhaps the actual coating on the table has become degraded and sticky. To resolve this issue, you'd most likely need to remove the coating by sanding and re-apply a new one.
Do you know if it is solid timber or a veneer?
