Hi everyone!
I have all but one of my panels up. The one that hasn’t been glued and nailed in is marked with a blue arrow. I’m not too sure how to fit this one in because I can’t seem to manoeuvre my fingers to push on the right hand side edge of the panel to fit the groove over the green tongue of the panel that’s already up. The panel that’s up and has the green tongue is marked in green, along the side where the tongue is.
Any ideas how to do this other than to trim the panel a bit more? I’m worried that if I do that, there will be too wide a gap to fill up with “no more gaps”. Even if I trim it though, it still feels like it would be a tight space to work with. All of this is made harder by the fact that I need to prop the board up on spacers to create a 10mm gap with the floor. When I try to connect the panels from an angle and subsequently swing the panel forwards to the wall, it often loses contact with shifting spacers or moves the spacer and that means my panel drops to the wrong level. On one of my dry runs, I managed to get the panels somewhat joined together, but it was not great as I could still catch a glimpse of the green tongue! It’s all just very cumbersome. Any help would be much appreciated!
