Would like to purchase rubber seals for my living room and bedroom aluminium window frames and watch a video education on how to install.
Hello @GAB1
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about replacing your aluminium window rubber seals.
In order to give our members a better idea of what the rubber seals look like, would it be possible for you post a photo of one of the windows where the seals have deteriorated? Once we've seen the photos well be able to offer recommendations on how to proceed.
Are you referring to the weather seals around the aluminium frame or the rubber seals on the glass window itself. If you are referring to the glass rubber seals, I suggest engaging the services of a qualified glazier or aluminium contractor to replace the seals on the glass window. The glazier or contractor will have the proper tools and equipment to replace the rubber seals safely.
Please do not attempt to remove the glass from the aluminium frame. It might crack or break apart thereby causing injury.
