internal brick wall of 140yr old double brick house has a 2-3cm cement type covering/render (rough texture) which then has a thin white covering for a smooth texture, then paint, them several.lauers of wallpaper. What would the cement like cover be - my guess its original to the house.
After removing wallpaper this surface is crumbling in some areas.
How do I seal or bind it and then create a smoothe surface for painting.
As it's only on one side I am quite willing to put up a feature lining instead of painting.
Damage may have several causes - massive floods that entered house and roof was damaged for years- now repaired. Also faces south, so should external brick wall be sealed with something.
