I'm preparing to repaint and have chipped off some plaster that was really loose, with both of the holes shown here covering the electrical wiring down to power-points & light switches. I think that was the cause of the plaster coming loose too. The large hole is about 60cm wide + 50cm high. I've previously used Poly Multipurpose Filler for smaller holes & that's worked well, but I think these areas are getting beyond that. Do you have any suggestions? Do I need a plaster base + top coat, or will a single-coat product suffice? The depth is about 10mm too.
