I wish to build a deck about 3m x 3 m or so. The deck will be about 600 mm above ground level. I intend to use timber boards supported by 100mm joists with 200 mm beams underneath.
For the decking I might also use the Merbau panels approximately 1100 mm x 550 mm sold by Bunnings
So the subframe will be around 300 mm deep.
I will put brick or concrete pads underneath for supporting piers. That means my so-called piers will be around 300 mm in height only. Of course I could use Besser blocks or bricks but I have heard about an adjustable galvanised steel system. It would consist of steel posts that I can fine tune to get the subframe at the exact height, The point being that my site is slightly sloping and it would be good to just be able to quickly level the thing up instead of fiddling around with bricks and then mortar layer on top (in the good old days we just put pieces of fibro).
Also, Using short steel posts would be good for proofing against white ants/ Termites.
So here’s my question has anyone heard of a system of adjustable steel posts which I guess would be made out of Square hollow section or circular section galvanised steel with some sort of hole-and-pin system to be able to fine the height of the post.
