The perfect way to serve those little titbits to your friends over summer inside or out.
I’ve used untreated pine boards from Bunnings and in particular Seles finger jointed 450 and 600 mm wide pine panels.
these give great choice for drawing a shape you like. I’ve cut out shark (sharkcuterie after all) 😀 a penguin and sea horse, and a rabbit as well as octagon, circles and triangle shapes. Generally 300 diameter 350 and 400 are popular.
I sand them with a range of grits 120/180/finishing with 240 grit. I’ve made some with square cut edges. Shapes are cut out with a Ryobi jigsaw using a fine wood cutting blade and sanded around the details with a Ryobi multi tool.
some I have routered the edges for added finish using a Ryobi trim router.
happy to answer any queries and help you get started these do sell if you want to make a few bucks.
I finish these with food safe bench oil available from Bunnings
