Hi all,
i started to build a floating deck in the backyard and i am planning to put on top of the deck an inflatable spa (https://www.bunnings.com.au/bestway-1-80m-x-66cm-lay-z-spa-tahiti-airjet-inflatable-spa_p0262778). I am not sure however if the deck can hold the weight of the spa plus two people? If yes, anything you recommend to keep in mind as i go ahead with the project and to reinforce the deck. Dimensions below
Deck Size - 2.8 mt x 3 mt
Pool Size and Weight - 1.80 mt x 0.66 mt (inflated size); 1.32 mt (inner size); 696 kg (filled weight)
Two People - 150 kg (approximate weight)
