Hi All,
We are currently planning to build our ecodeck over an existing concrete slab under the alfresco. We dont have much experience however we are willing to learn as we go and take inputs from you all. I have seen quite a number of posts and decided well we can do it ourselves too 🙂
To start with the dimensions of our alfresco is 3.1m*3.6m. there is a 149mm stepdown from the living area. it can be seen in the attachments.
My questions are twofold:
1. is with regards to the sub structure
2. one is with regards to the ecodeck itself.
I will start of with my questions in relation to the sub structure as I want to get this one before I lay my Eco deck.
Question 1: How do i get the 149mm height of the deck to the brick face?
My 2 cents: using brackets which will be dynabolted to the ground along with 20mm packers OR use a combination of 90x45(bearers) along with 70*45 (joists) and packers- (45(bearer) +70(joist)+10?
Question 2:
spacing the joists at 450mm apart is what i plan to do. However I have often seen that towards the face of the wall some people use 2 joists and add small noggins between them? is that so that they can picture frame the deck easily?
If I were to follow a similar process how do i attach the joist next to the brick wall?
Your response would be really appreciated.
J
