How many builders edge pedestals for low-level deck?
Rob7
Hello
I'm building a low level deck over concrete with a slight slope. These builders edge pedestals will be just right for getting level joists, https://www.bunnings.com.au/builders-edge-35-60mm-smallfoot-pedestal-feet_p2450074 - I just need to know how many to use.
The joists will be 90x45 F7 H3 pine. Question is should I space them apart using span table measurements for 90x45 pine from AS1684 or do I need to get them closer together (i.e. use more)
Rob
Re: How many builders edge pedestals for low-level deck?
Welcome to the Bunnings Workshop community @Rob7. It's great to have you join us, and many thanks for your question on pedestal feet.
Span tables are exactly what you need to reference. As a ballpark figure, I'd suggest a foot every 900-1000mm would be adequate.
If spaced according to span tables, the feet will be more than capable of supporting the deck's weight.
Excellent, thanks Mitchell
