I've just installed a concrete patio and after a heavy downfall the rain has highlighted where I need to place some drainage.
Based on the attached pic, I was wondering what the easiest solution would be to draining the water from the patio. I was thinking of digging down near the downpipe and adding a junction to the downpipe as well as a shallow drain placed next to the downpipe - this would allow both water from the gutters and patio run-off to flow to the stormwater.
Another solution may be to cut the downpipe and add an open grille drain below the downpipe and just allow any run-off from the patio to drain away too.
Any advice would be much appreciated.
