Hi there team Bunnings,
Hope you are well,
I was wondering if you can kindly help me with the following as I'm planning to build a low level deck due to land sloping down towards my backdoor.
1. My pergola is 25sqm, would I need to connect the downpipe to a storm water drainage? the downpipe is on the last pole on the right hand corner. The storm water connection is very far down the house on the side.
2. What is the minimum clearance would I need for a low level deck if i'm planning to use Galvanised post, H4 for bearers and H3 for joist?
3. As my land slopes down towards my back door and water seems to flow towards the house, is there a drainage issue I need to think about? If so, can you please kindly recommend me a solution?
4. I plan on digging up the grass, which weed mat would you recommend to purchase? Would you also recommend the clips or drainage sand?
Any additional advice to what I have not thought of would be much appreciated 🙂
Many thanks for your help!!
