Hello brains trust,
First time poster, long time lurker. I will be installing a timber retaining wall around my pool area, and then installing a glass pool fence on top of it. I intend to use 200 x 100 mm hardwood sleepers for both the posts and rails. The retaining wall will only be two rails high, with a 200 x 50 mm hardwood sleeper to cap it off. This will make the total height of the wall 450 mm's high.
The post holes will be 600 mm deep, and be placed every 1200mm.
I have two questions.
1. Which cement to use in the holes? Obviously I need a strong wall to hold the weight of a glass fence. Should I use one or two bags of cement per hole? And is there a brand or strength of cement you would recommend?
2. Would the 200 x 50 hardwood sleeper cap be thick enough to hold the weight of a pool fence without warping, or would I be better off not using it at all and placing the fence directly on the rails?
The photo is not my fence, but is the style I am hoping to achieve.
Thanks
Darrin
Not my fence, but is the look I am going for.
