We are currently undertaking large backyard renovations and I will be performing a large part of a studio build as part of that.
The concrete slab is already laid and 2 sides will be easy to frame and clad on as they are open and the edge of the slab falls off into garden and landscape areas however 2 sides will be up against besser block retaining walls, one will not be very high but the other will be about 2 thirds of the way up the studio wall in height from the slab. The plan is to have a small cavity (100mm) between the retaining walls and studio so there is no risk of water finding its way through the walls by direct contact but there will be a small cavity with no room to really perform any work in that cavity so I had a few questions as to how I should build those walls.
I plan on it being a timber frame and likely weatherboard cladding studio with an external wrap between the frame and cladding and my questions relate to how to get the wall built while getting it weather tight.
The retaining wall sides are completely hard surfaces with the concrete slab butting up to concrete besser blocks there is no drainage on them (agg lines and drainage behind the retaining walls and once the studio is up the gutters will overhang the cavity but still a small chance of water finding its way down there). So I want to make sure I have a complete seal around the bottom timber plate so water cant soak through there at any point.
1. Should I therefore put in a bottom plate around the entire external wall into the slab first (its simply a rectangular build) secure it to the slab with a damp proof course between them and then I was thinking to silicone the join at the bottom of the frame too in case of any sitting water in that cavity?
2. If I do the above should I use treated timber for that bottom plate just as an added protective measure or no point?
3. I was then thinking (for the studio walls against the retaining waters) frame them up on the ground as I would do with the other walls but then also brace, wrap and clad them possibly just simple sheeting as it will be hidden (at least as high as the retaining wall where I wont be able to work behind) while on the ground so I can then stand them up on to the bottom plates I have already attached and can then connect them through into the slab effectively ending up with a double bottom plate. Is this the best approach as I cant think of any other way to make sure that I can get those walls built?
4. Is there anything I can or should add into the cavity between the walls to try and drain out any water that may find its way in there so I don't end up with any standing water?
Any other considerations I should account for as well would be a good help thanks.
