Hello,
What product we can use to do German smear on the exterior wall?
Hello @Elena145
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thank you for sharing your question about applying a German smear on your exterior wall.
If you've done this type of application before, I suggest using Easy Mix 20kg White M4 Mortar. I recommend mixing only the amount you'll be able to use for the moment. Mixing a large quantity is not advisable as you might not be able to use the entire mix and end up wasting the mortar.
I suggest looking at the different types of German smears and seeing which one you would like to apply to your wall. Please keep in mind to give your wall a thorough wash to remove all the dirt and debris before you begin.
Here is a handy guide on how to use the Easy Mix Mortar: How to German Schmear with cement-based mortar.
Thanks EricL,
can I buy Easy mix M4 mortar from Bunnings?
Hi @Elena145,
If you tap/click on this Easy Mix 20kg White M4 Mortar link, it will take you to the product on our webpage. You'll then be able to select your closest store to check availability.
Please let me know if you have any difficulties.
Hi Mitchell,
unfortunately, Bunnings does not have this product in stock and on the shelves, and never had. Any recommendations on the products Bunnings has.
thanks
Hi @Elena145,
I apologise as it appears the product mentioned isn't available in your location.
We don't often stock white cement or mortar, and no ready-to-use white mortar is available. We have Off-White Cement, which is significantly lighter in colour than standard GP Cement. However, it's typically a light grey and not white. To create your mortar mix, the cement would need to be mixed with White Sand and Hydrated Lime
One of our suppliers, Dingo, do have White Cement, and it would be worth speaking with your local store's Special Orders desk to see if they could order you some. If you were looking to make a brilliant white mortar, using white cement would be more suitable than off-white.
Thanks - that’s great advice and we’re keen to implement.
In terms of cleaning the brick before applying the schmear - we have a simple lime wash on our brick (applied about 6 yers ago). Will a pressure cleaner remove this - of will we require a stronger approach??
Many thanks!
Ben
Hello @benb1973
I'm afraid it will be necessary to remove the line wash on the brick surface. The limewash acts like a coating on the surface of the brick wall and covers its porous surface. The porous surface is necessary for the mortar schmear to anchor onto the surface of the brick wall. Simply washing it with a pressure washer will not be enough to remove the limewash. One possible way is to remove the limewash is to mechanically scrape it off the wall using a Craftright 75mm Crimped Cup Brush and a grinder. Please make sure to wear full PPE such as long-sleeved shirts, long pants, closed toe shoes, gloves, goggles and a mask.
The other method which is acid washing will require the services of professional. The use of acid chemicals is not recommended as a D.I.Y method. The professionals will have the knowledge and experience on how to use the acid wash safely and properly.
