I want to install a 2.4m high 4m wide trellis to support a climbing Rose.
I've got 50x50x2mm gal steel for posts and a brace across the top.
I am looking at using 3mm gal wire rope strung between the 2 posts at 200mm spacing, from about 800mm off the ground.
What's the best way to attach it?
Will these wire straps be suitable to attach with tec screws to the 2mm wall thickness? Are they best attached to the inside face or front face of the posts.
I'd like to tension it using a turnbuckle.
I'm open to other ideas.
