Hi, we are building and the way they have cut/filled the block has left us considerably higher than our neighbour and a concrete retaining wall has been erected 400mm away from the existing colorbond fence. the depth is between 1000mm and 1500mm for most of the length of the block. I have seen other similar situations rectified by putted decking across however that was being supported by a timber fence. We can't back fill as that will eventually pop out the colorbond fence on our neighbours side. Any suggestions would be welcomed. Thank-you
