would 2 x 2100 blinds fit a 4250 space ,and will the blinds zip together TIA
Hello @Tezza27
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your patio blinds.
The patio blinds will often require a patio blind joiner which is usually 100mm across which means that the space you have is 50 mm short. The ends of the blinds will therefore bend in, and you'll not be able to roll it properly. I propose visiting your local store and speaking to the special orders team in regards to quoting you custom width patio blinds. My best advice is to double check your measurements of your opening width before visiting the store.
