Hello!
I have a small concreting job I would like to tackle myself if possible. I'm looking for a concrete pre mix product that is ready to go without mixing water. Does a product at Bunnings like this exist? Any advice would be appreciated ![]()
Hello @Heidi1
If you have a trowel in your possession that would be the tool to use for this project.
Hi @Heidi1,
The effort as you will see (for your job) to mix mortar is about the same as doing the pastry thing in the kitchen or even general house cleaning.
You may be more concerned about the weight of the bag so let's run through this overview with a focus to minimize handling:
Find a strong carry bag and a pull-tie rubbish bag.
At Bunnings put the Dingo bag into pull-tie and then into carry bag.
If needed as for assistance to check-out and/or get it to your car.
For small jobs (like yours) I use a kitty litter tray for mix-up.
If needed first get that and also a pointing trowel.
Back home leave everything in the car until ready to do the job.
When prepping for mix up in the kitty litter tray simply spread open the zip-tie bag and when finished pull hard on the ties, tightly twist and seal with whatever (cable tie/tape/string) to keep moisture out of the Dingo bag and store in a protected dry place.
I spent some time composing all that because I am keen to encourage the DIY thing.
Looking at that photo it's likely you will be doing the same thing again.
Come back if you need more assistance...
Morning @Heidi1
If you dont have a trowel, id be tempted to use a large paint scraper as a substitute.
