Hi all,
I've begun building a fairly simple timber gate for the side of our house following along with this Bunnings how-to video:
https://www.youtube.com/watch?v=0ZbQpZgMJ1I
The timber is 70mm x 35mm treated pine.
The screws are 14G 150mm galvanised batten screws
When measuring the frame from one corner to the other on both sides to check if it's square I've found one to be out by 9-10mm (see pics below).
I'm looking for any advice on the following;
a) How do I adjust the frame to make it square with all the screws done up?
b) What are the consequences if I left it as is, added the diagonal supports and pailings and then hung it?
I've tried to straighten the pieces up with the help of a 600mm rafter square but just can't get it to sit right or tightening the screws pulls it of alignment.
Any help is much appreciated.
The basic frame
corner to corner 1: 1951mm
corner to corner 2: 1942mm
2 bolts used to fix each rail to sides
