With all the recent rainfall water has seeped into my basement about 2 cm deep which we have managed to scoop out. Its happened a couple of times over the last few days but after 24 hours it is mostly gone.
A brickie who was looking at the basement a few weeks ago said the house and basement were pretty dry except a bit that butts onto the side path and did suggest at sometime to put a channel against the wall. So the time has come.
I've had some advice but am getting differing opinions, so I would appreciate some advice on the correct way.
As a temporary/quick fix I've dug a trench against the house about 150mm deep and a spade's width.
I plan to lay the Ag pipe to the garden and let it drain out there as I have no access to a drain.
This is my plan :-
- Dig the trench further to about 300mm deep past the house render exposing about 2-3 layers of brick.
- Waterproof the brick work - 2 coats
- Lay plastic sheeting in the trench making sure it lies against the house wall bricks
- Lay some blue metal or other suitable
- Lay Ag Pipe
- Cover Ag Pipe with a second layer of blue metal
- Cover Blue metal with path/sand gravel similar with what is already there for the path
Is anything missing? Should I consider installing a small pit or can I just let it run into the garden? I imagine the small pit would just fill up anyway.
Is the above correct? I've also been told to lay the Ag pipe directly on the plastic sheeting and then cover with Blu Metal (so only one layer of Blue metal). Also I've read not to use any plastic sheeting.
Would also appreciate some details on which materials to buy :-
Pictures attached,
Many Thanks
Tim
